How do you delete songs from an ipod shuffle from scratch and put songs on to an ipod shuffle from from scratch from win7
You can uncheck the songs on iTunes library first, and then sync iPod with iTunes, the songs will be deleted from your iPod. Or you may try this iTunes alternative, it's easy to delete your iPod songs, videos and photos.
http://www.reviewstown.com/itunes-alternative.html
Hope it helps. Feel free to email me if you need further help.
SOURCE: WHERE TO DOWNLOAD FIRMWARE FOR IPOD SHUFFLE
Try setting a partition in hard drive management then formatting it to FAT32, since you might have formatted to NTFS
SOURCE: usb driver for ipod shuffle
Hi!
You need to have the software Itunes to copy the song on your computer to your IPOD.
Once the shuffle has been detected by the computer, you can then use itunes.
SOURCE: iPod shuffle
just to clarify.. you have installed itunes on your computer and are using itunes to transfer songs? this is how it is done
SOURCE: Deleting songs from Ipod Nano 8GB
When you connect the ipod nano to the computer, you can do one of two things: you can go to the ipod's main home page in itunes and go to the bottom where it will have four options listed. 1 of them should say manually manage files. Click on the check box next to it and it should ask you if you are sure and click yes. Then go into your music folder of your ipod and delete the songs you don't want on there. To add music, all you have to do is click and drag what you want onto the oped. The second way you could do it is to go into your library before connecting your nano to your computer and un-checking all of the boxes next to the music you do not want on your nano and then connect it to a computer and let it sync. The first way is easiest and less time consuming as you only have to do it once. Hope this helps!
SOURCE: Shuffle does not play all songs
maybe thats because your uploading it from another source that doesnt always work out the way it supposed to be
