I have bsnl broadband connection how can i configure bsnl adsl modem with TP-LINK TL-MR3420 router!
TP-Link Router not working, want to setup TP-Link router, have troubleshooting issues. No need to worry we are here to provide you the best solution according to your requirements of router issue. You just need to dial TP-Link Router Helpline Number avail at toll-free number 1-833-284-3444. Our tech support team includes executives who are professional and know each & every solution which may arise at the time of accessing.
The wireless network is unstable via my wireless router/modem router
Some time router is not still connected and working that time users do follow given instruction and make the trouble-free router.
Locate wireless clients in a reasonable distance.
Get away from obstacles.
Reduce the number of wireless clients.
Decline interference from other wireless equipment.
Optimize the router's position.
Change some settings on the router.
Test the WIFI device.
Get technical service for your problem which is not understanding how to solve the technical issue, our technical expertise is available for 24*7 and they are ready for pick up the call when called by the customer. If wants to more technical service visit our TP-Link Router Service websites.
https://servicenumber.org/tp-link-router-customer-service.html
Make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
SOURCE: Must be reset router tl-mr3420
1.You will possibly need to configure the router for what is called "port Triggering"
2. from what I read is that there is no IP via the Hikvision external there fore requiring a new IP each time for connectivity.
Instruction set from the manual states:
To add a new rule, follow the steps below.
1. Click the Add New... button, the next screen will pop-up as shown in Figure 4-40.
2. Select a common application from the Common Applications drop-down list, then the
Trigger Port field and the Incoming Ports field will be automatically filled. If the Common
Applications do not have the application you need, enter the Trigger Port and the
Incoming Ports manually.
3. Select the protocol used for Trigger Port from the Trigger Protocol drop-down list, either
TCP, UDP, or All.
4. Select the protocol used for Incoming Ports from the Incoming Protocol drop-down list,
either TCP or UDP, or All.
5. Select Enable in Status field.
6. Click the Save button to save the new rule.
check the "Local management" in the router
you must allow certain devices to obtain an IP via either MAC address or IP address.
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
SOURCE: disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Testimonial: "Hi, I've finally found some time to test the dissabling the FW and I can say that in my case it helped. I can see now from TP-LINK IP cameras connected to the VDSL modem/router. Well done guys, thank you for your help. Kvinar"
SOURCE: TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
SOURCE: TP-LINK TL-WR740N 150Mbps Wireless Lite N gives only 54 Mbps speed
Change the browser settings on your computer, so that when you open an web page no animations, graphics, video, sound or other multimedia content appears. The multimedia features usually take up a lot of bandwidth space. Turn off your media browser settings by selecting the control panel option on your computer and opening up the internet options. When the internet options come up, left click the tab that says "advanced" and scroll down to multimedia. Deselect the multimedia options and save your changes. Clear out unnecessary information in your Cache and Cookies within your browser. Cache and Cookies work to store information from the internet like passwords and log-ins. However, they also take up a lot of bandwidth space. Click the tools tab in your browser, select "Clear Recent History" and then select which files you'd like to clear. Press ENTER or CLEAR NOW an then save your settings Visit sites like SpeedTest.net to test your bandwidth. Click the Begin Test icon and notate the bandwidth speed test results. Most often when you sign a internet contract you are guaranteed a certain speed that your computer will operate at. The results presented are a user's download and upload bandwidth speeds. These results allow you to measure how fast your computer is downloading and uploading information. Look at your internet contract with your service provider. If your modem is operating under speed, contact your service provider and have the representative reset the bandwidth or make a request to upgrade to a faster modem. When your ISP offers you a 1Mb connection, its megaBits not MegaBytes. So for a rough guide of how MUCH you can download, divide by eight. i.e. 1Mb speed = 128KB of data. you have Download all of your favorite videos, programs, games, and music with acceleration. http://download.cnet.com/cnet-bandwidth-meter/3000-12565_4-10728035.html The CNET Bandwidth Meter tests the speed of your Internet connection against top DSL Cable modem, and other broadband services. To check your bandwidth, simply click on the download link.
Speed Test provides a free broadband connection analysis that test a user's internet speed against other servers.
Compare the notated Speed Test results against what your bandwidth is supposed to be according to your contract.
Hard wired ethernet is much faster than wireless
So its normal for you to get 1.0-1.10 mbps download speed for the 10MBps connection that
http://download.cnet.com/getgo-download-manager/3000-2071_4-10277023.html
hope this helps
tell me full configuration process.
