Https://www.google.co.uk/search?q=Hitachi+CP-X253+bulb+replacement.
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
The
process for replacing tail light bulbs is the same in all models. If
you have a burnt-out tail light bulb, you may need to replace the
brake light, the reverse light or the turn signal. The procedure to
replace each of the bulbs is the same.
Instructions
1.
Open the Hummer's rear swing gate. This will expose the edge of the
vehicle's tail light assembly. You'll see two small Phillips head
screws that hold the tail light assembly in place. Put on your
gloves.
2.
Remove the two screws from the tail light assembly. Pull the tail
light out and inspect the back for two bulbs. The top bulb is the
brake light and turn signal. The bottom bulb is the reverse bulb.
Determine which bulb you need to replace.
4Push
the replacement bulb into its socket firmly. Insert the socket back
into the tail light. Turn it clockwise to secure it in place.
5Place
the tail light into its cradle. Hold it with one hand and replace
the Phillips head screws with the other.
