if it is kicking off after u release the dispense button but still drips a bit then id say that the electric water solenoid is the problem not completely shutting off
Hi, If the water is dripping from the dispenser tube, you need a water
valve. The valve is not shutting off completely. Check to make sure
water is not dripping from ice chute. If the chute door doesn't seal
off you will get moisture there and it will also frost up the ice
chute.
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Hi, this is a faulty water valve assembly that is not shutting the dispenser section completely. replacing this water valve assembly will fix the dripping issue you are having at this time.
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself. click here for a walkthrough
for your drip: Flush air from the water system the first time it is used and after
replacing the filter. Air trapped in the water line or filter may
slowly travel through the coiled water reservoir to the dispenser,
pushing any water ahead of it. This can cause the dispenser to
drip. Water needs to completely fill the lines for all air to be
cleared.
Use a sturdy container to press and hold the
water dispenser bar for 5 seconds, then release it for 5 seconds.
Repeat until the water begins to flow. Once the water begins to flow,
continue pressing and releasing the dispenser bar (5 seconds on,
5 seconds off) for an additional 2 minutes. Repeat if dripping starts
again because air can re-enter from the water supply.
As air is cleared from the system, water may spurt from the water dispenser.
Make sure the refrigerator is connected to a cold water supply.
One
or two drops of water immediately after dispensing is normal. It may be
necessary to hold the container under the dispenser for 2 to 3 seconds
after releasing the dispenser lever.
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
