SOURCE: cannot connect to the monitor with one computer.
the compression in the PDF output tab that was causing the issue.
We print on a Durst Lambda RGB imaging device to photographic paper. All color management is done as an early bind (raster files are converted to the printer's color space and vector colors are chosen from a palette database). So basically the files must go through InDesign without any color change in raster or vector information. We have clients that require specific RGB builds for logo colors the are present in both their raster and vector files.
Color Management is set to "North American General Purpose 2" with "RGB: Preserve Embedded Profiles" selected.
1) The file is exported as a PDF 1.4, High Quality, PDF/X_None.
2) The PDF was ripped on a Cheetah RIP (Jaws level 3) with no color management on.
3) Solid raster colors such as 0-255-0 will reproduce as 0-255-1.
4) The color differences between the raster and vector are usually 1-4 points.
5) The vector is consistent as was input in the program—it's only the raster that changes. When you are trying to match raster and vectors logo colors it is a killer.
However, I can go into the InDesign (or Illustrator) color settings and turn color management off (This is our current workflow). In doing this the RGB working space uses the monitor profile and "color management policies" are set to OFF. With these settings the RGB raster and vector match. The problem with this work flow is two fold:
1) We have other devices than our RGB Durst Lambda that can use the InDesign color management—Vutek flat bed 3200 and grand format 3360.
2) We have had many occurrences where the custom "color management off" settings have reverted back to the default "North American General Purpose 2"—without any intervention.
SOURCE: BELKING SWITCH2
I've had one of these switches for a few years now. Just recently hooked it up again, only this time using a MS cordless mouse and keyboard. A bit different than the old wired mouse and keyboard I was using a few years ago, and we ran into this issue this time.
The switch requires the ScrollLock and the #2 to be keyed to switch. Twice on the ScrLk, then the 2 (on the number pad). After trying it with the wired keyboard and it worked, I looked at the wireless keyboard and noticed the ScrLk key was a function key. Hit the F Lock key and tried it again, and it worked this time.
I also found that with the power settings in the "save energy" mode, it had a tendancy not to switch when the other PC was asleep. Try hitting the reboot button to wake it up, and that might help.
Key things: Scroll lock key activated by hitting the Function Lock key. Wake up both systems so you know they're paying attention.
Hope this helps.
SOURCE: KVM Monitor resolution out of frequency and will not display
Restart your system in a VGA mode (you will find this below Safe Mode, by pressing F8 before windows is loading) This way yours screen resolution will be at the very low frequency then you can change it back to the resolution you like. Eg. 800x600 or 1024x768. Remember to keep your Screen refresh rate lower like 75Mhz
SOURCE: mouse and keyboard not recognized on second computer
Sounds like KVM has a bug. Maybe their website has a fix.
SOURCE: using KVM-121 with 2 monitors
You should be able to -- the KVM switch would just switch inputs for the monitor, but since your two monitors would be plugged in directly to your computers, the switch wouldn't actually be affecting your monitor inputs.
Just make sure to plug your monitors directly to your computers and not use the switch.
