Assuming you have the programming manual: get into program mode- press transfer button then 800; enter passcode (default is 4321); press volume up button to get "enable" on LCD screen; press speaker button; press 722; press extension number you want to add VT to; press button number of phone you want the VT to be on; press button to left of round scroll button; press 8 on dial pad 3 times to get to V options; press up/down arrow until VT appears; press Voice mail group number (509, 519, 529, 5049)- depends on what model system you have; press button to left of round scroll button; finally, press transfer button. you're done.
SOURCE: The display on my Samsung iDCS 28D phone has gone blank.
hi,
if the display of your phone has gone bad, try do the following.
open the phone with a screw driver carefully.
after opening, find were the flex of the screen is connected to the phone panel.
make sure you fix the flex firm on the panel, then close the phone and switch it on.
if the problem continues, you will change the flex of the phone.
SOURCE: i need to program my Samsung system idcs 28d to
From any phone: press transfer button, then 800, then passcode 4321, then press up arrow on volume and set to enable mode, then press speaker button, then type 722, then type the ext number you want to change (eg. 201), then move the cursor under the 01 and type in the button number you want to add barge to, type the letter b and it will list all the features that begin with b, choose barge the press the button next to the scroll, then press the transfer key, you're done
SOURCE: I have the samsung IDCS
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
SOURCE: how do i change my voicemail greeting on my
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
SOURCE: On my Samsung idcs 28d,
Hi, to change your day greeting on a Samsung iDCS 28D, iDCS 18D, DS-5021 and DS-5014 telephone:
I started working at an RV dealership and the phones do not have an existing VT key. Is there a way to program one?
