Krups Dolce Gusto KP 2100 Espresso Machine Logo
Robin Bettridge Posted on Jan 30, 2014
Krups KP2100 One light press on the power button causes the power to flash red twice, then stay off. I have been able to hold the button for >5 seconds to get the light to begin flashing green (descale mode) then move the lever over at the top and start pumping water. There was no apparent issue with flow or temperature recently and no unusual noise from the pump. After observing some water being pumped for a few seconds I now have lost the pumping functionality completely. A momentary dab of power just gives two red flashes. A 5 second hold gives green flashes, but the top lever no longer starts the pump. I have filled the water tank to a higher level than I normally use (to hopefully ensure water pressure and no air-lock possibilities). Cost of return for repair does not look economic. Is this something that screwdrivers and a trip to Maplin may be able to solve?
wwwkamran786
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 30, 2014
wwwkamran786
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
533
Points
5
Satzo software did not hacked any account why
1 Related Answer
Sergio M Perez
  • 39 Answers
  • Posted on Dec 29, 2009
SOURCE: Krups XP2070 Stops putting water through after a
Most likely a faulty flow meter unit which is not providing the right information to the control unit. Replacing is not too difficult and the replacement meter is < $20.
2helpful
4answers
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &amp;#147 key. Where or what is "&amp;#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
2helpful
2answers
Dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
1helpful
I bought a Sony BDV-E570 in US and it came locked for region 1. As I live in Brazil, I need to run region 4 dvds. Do you know how to unlock it? Thanks
NO LIABILITY IS OFFERED HERE!! THIS IS A HACK!!!
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
This worked for me, but obviously I accept no liability for anyone who tries it on their machine.
I forgot the code of my chunghop universal remote RM - 133 E my tv is JVC
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then do these procedures
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
1. PRESS and HOLD the SETUP button until the red LED flashes twice.
2. PRESS 9 - 7 - 5, the red LED will flash twice.
3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
4. PRESS the button that will receive the learned function, the LED will flash rapidly.
5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through
6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
How do you get BDP-S360 to play all regions?
hi,
to make ur player region free for dvd u should have a Oneforall universal remote wich acept 4 digit code
Firs of all u have to program the remote for the purpose. procedure is as follows
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S360 region free:
ok
4helpful
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
17. Press 00095
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
They said to put in the code the red light have to stay on on mine the light blink twice it doesnt stay on
1. Select componet
2. Press and hold SET button until it flashes twice.
3. Enter 4 digit code ( long flash when last # entered)
4. Try power to check function
LOOKING FOR HACK CODE AND REMOTE CONTROL MODEL NUMBER I SHOULD USE TO DO THIS
one for all rc 7652 works for this as do many others.
1. Press DVD
3. Press 000533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
7. Press 001891 (this sets key 1 – the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 002552 (this sets key 2 – the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 000953 (this sets key 3 – the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 002214 (this sets key 4 – the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 000795 (this sets key 5 – the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Quote:
1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
2. Make sure there isn't a disc in the machine.
3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
4. Put the player back into standby with the Sony remote
5. That’s it, the next time you turn on the player it will be region free for DVD playback
I personally dropped the 00 that are marked red and it worked for me but it depends on model of one for all remote.
Programing my new remote
If none of the codes work then we have two other solutions:
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
