Faber Inca HC SS Stainless Standard Insert - 630002752 Kitchen Hood Logo
Posted on Jan 30, 2014
Faber model inca hc 72. The fan makes an odd noise. It still works. it is 11 years old.
faberfixer
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jan 30, 2014
faberfixer
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
4094
Points
14
Your hood probably needs a service call to examine the motor, please visit http://faberonline.com/service.html to find your local service #, thank you
2 Related Answers
Anonymous
  • 833 Answers
  • Posted on Dec 09, 2007
SOURCE: Fan Not Working
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
faberfixer
  • 12 Answers
  • Posted on Jan 11, 2011
SOURCE: our Faber INCA HC HILO
You can call Europarts in Toronto for service at 800-678-8352
The fan making a noise when in use how can this be fixed?
My guess that it is a lack of lubrication problem. If the fan bearings are now worn to the point that the fan is touching something it may be that you have waited too long to save it.
Can you send me a link for instructions on how to install the hood?
http://faberonline.com/technicalspecs.html for instructions on all models, thanks
2answers
Carol LeBlanc
please follow this link to find a servicer: http://faberonline.com/service.html
Where can I find a replacement plastic light cover for the left side of 5974890
not enough information but the best move will be to contact the service agent for the unit or manufacturer spares on the web page
Inca suction
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
1helpful
I replaced the bulb on a 72" toshiba because the old one was flickering after almost 3 years.the new bulb slid into place perfectly but no picture.I placed the old one back in and now it does the same...
Hi,Did you close the door cover? Did you reset the lamp timer? To do it you can just unplug it wait 5 min and plug it back again. Make sure the fans are running ok.Pay attention to any strange noises ,if you hear clicking or like wanting to turn on , it could be a ballast issue which is the board that powers the lamp.God bless you!
I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
Fan Not Working
Top Faber Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
