If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
SATA HARD DRIVE ? XP INSTALLATION The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive. If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
The BIOS should not prevent you from installing Windows XP. If your hard disk is a SATA hard drive then - The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
If you are trying to install Windows XP on a SATA hard drive then. The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again. The hard disk maybe faulty, if so you need a replacement. If the BIOS detects the hard disk and you are installing Windows XP then - The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
If you would like to make use of the SATA controller's AHCI features, you should enable
this BIOS feature. But please note that enabling this feature requires
you to load the SATA controller driver during the Windows XP
installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable
this BIOS feature. This allows you to use the native Windows XP driver.
You won't need to load the SATA controller driver during the Windows XP
for bios update go to manufacturers website but to install xp sp2 on this lappy you will have to install third party raid driver and legacy device driver that you can download from www.download .com
Are you trying to install Windows XP on your laptop that has a SATA drive in the laptop?
And during the Windows XP install it cannot find a hard drive?
The reason why Windows install does not work is because Windows XP does not have a SATA driver support and therefore cannot find the hard disk.
THE FIX THIS PROBLEM.
Go into your BIOS and turn off Native SATA support or set it to IDE controller (this setting depends on the type of BIOS). Save the setting and reboot and you will be able to install Windows XP.
its most likely your hard drive is not recognized by xp because it is a SATA drive. You need to go into your BIOS and set the compatibility mode for sata. or if your bios does not have this option then you need to install the drivers when xp asks if you would like to install any third party drivers during setup check with your manufacturer for the required drivers
