The machine will keep on asking for toner even when there is toner in the cartridge.at time it print jos 5 copies and ask for toner even when there istoner
Replace the image unit for that color and replace the toner cartridge with oem cartridge
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: toner
Di200
[Subject]
"Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Description]
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
SOURCE: One Copy At A Time
Are you setting the quantities in the driver properties or just in publisher? If so, do the changes reflect in Publishers settings after setting the quantity in properties. Does this only happen from Publisher, if so then it sounds like yet another MS issue to look into and not with the printer.
SOURCE: error 2408
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
SOURCE: konica magicolour 2500W doesn't recognize cartridges fitted
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
1.
Turn the machine off, then wait a few minutes for the machine to cool.
2.
Open the front cover.
3.
Grasp the handles on the toner cartridge and pull to remove the cartridge
from the machine.
4.
Take a new toner cartridge out of its package.
Don't use sharp objects, such as a knife or scissors, to open the toner cartridge
package. You could damage the surface of the toner cartridge.
5.
Slowly shake the cartridge five or six times to distribute the toner evenly
inside the cartridge.
6.
Remove the paper protecting the toner cartridge by pulling the packing tape.
7.
Hold the toner cartridge by the handle and slowly insert the cartridge into
the opening in the machine. Tabs on the sides of the cartridge and corresponding
grooves within the machine will guide the cartridge into the correct position
until it locks into place completely.
8.
Close the front cover. Make sure that the cover is securely closed.
