Question about Casio Privia Px330 Px-330 88 Key Digital Piano New
Error loading - Casio Privia Px330 Px-330 88 Key Digital Piano New
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Mar 28, 2014 | Korg Pa800 Synthesizer
Not conect to computer with usb ctk 5000?
Unplug the USB cable.
Download correct driverfor your OS from
http://support.casio.com/en/support/download.php?cid=008&pid=20
You need to load the driver first and only plug in the USB cable when the software tells you to do so.
Aug 28, 2012 | Casio Ctk-5000 Electronic Keyboard Piano...
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Good evening, I have an MPC1000 with JJOS and was trying to save a beat and it just froze. Then I got an error message. I turned it off and on and it froze during A.Load. I took out the mem card and it...
I would look for either corruption of the file you loaded or attempted to save or if it might be too big to store in the unit.
It might be the memory card was not properly formatted for the machine.
A real problem is those who try to use a memory card that is bigger than the machine allows. MANY of them allow ONLY a 2 GB card maximum. If one tries to use a larger the units will freeze. Check that your card is listed as compatible as many, even the correct size, are not fully compatible.
Sep 04, 2010 | Akai Mpc1000 Music Production Center
How to fix Toshiba laptop with missing or corrupt file WINDOWSSYSTEM32CONFIGSYSTEM
There are many ways to attempt a fix with this error you could try firsta boot into safe mode then running msconfig
select the diagnostic startup then reboot in the normal way this might enable you to find your error.
If this fails click the LAUNCH SYSTEM RESTORE which maybe able to use one of your restore points created at an earlier time (usually before an app install) this may give you the fix you require.
Dec 14, 2009 | Music
I have noise on ram samples
Korg Pa800 Synthesizer i have noise on ram samples Answer i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion,... (More) i turned on my pa800 and when i play ram samples there was some noise like cracking and distortion, that happened 2 or 3 times, now its normal, but i think it may hapen again??? where is the problem, somebody says it is on motherboard? or its just ram overheating? since i install 2.01 os i noticed that its kinda warm in right display corner, can u help me???
Sep 23, 2009 | Korg Pa800 Synthesizer
I think my Micro BR is broken
It is either that you put an incompatible SD card in it. (Believe it or not, many devices will not work with certain SD cards), or the card reader has failed. Try a Scandisk SD card or other popular brand and see if there is any difference in the messages. Otherwise I would say the card reader is faulty.
Aug 06, 2008 | Boss Micro BR Digital Recorder
Casio Privia Px330 Px-330 88 Key Digital Piano New Logo
42 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
