Recently i have a thin blue line in all my pictures and on the screen. i noticed it when i was taking pictures inside a cave with many dark shots. it is on all my pictures now but is very noticeable with dark pictures. is there a way to correct this? i also have a stuck flach!! this has happened many times but i'm not sure how to fix it either. help please
SOURCE: THIN VERTICAL WHITE LINE on my photos
Close the lens with the lens cap set the camera in manual mode and take two or three shots. Or take shots at darkness still if you see the white line may be CCD or circuit fault.If you don't see it the problem is with the lens.
SOURCE: Nikon D70 Help
my nikon d70 used to have the lcd monitor on when i turned the camera on now the screen is blank anyone know how to get it to go back on
SOURCE: D40x flash not working
I have also had the problem of flash not working on my Nikon D40. I
found out the problem and I also made a quick video to help those who
are having this problem. Here's the link to the video: Hope this helps
Nikon D40 Flash Fix
SOURCE: NIkon coolpix L18 horizontal lines appear after taking picture
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
SOURCE: Cant take photos as it says the card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
