Question about Polaroid TLA-01911C TV
Polaroid tv remote codes tivo - Polaroid TLA-01911C TV
2 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: Polaroid TV remote control codes for Tivo
As I understand it, Polaroid TV's sometimes work with the Mitsubishi codes. You may give this a try. You may also e-mail Polaroid direct at www.polaroidelectronics.com contact page to find out what codes should be used (may match a different manufacturer)
Posted on Jun 02, 2009
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
I need code for RCA TV for Tivo remote
Go to http://support.tivo.com/app/answers/detail/a_id/294/kw/code%20search/c/105/r_id/100041 and under Programming TV Power, Volume and Mute, click on "show the steps".
Follow the instructions given.
The RCA remote codes are 0163, 0001, 0004, 0006, 0011, 0029, 0030, 0057, 0071, 0133, 0145, 0106, 0171, 0231, 0232, and 2210.
Try each of these codes one at a time (as per instructions) until you find one that works.
This link also gives instructions on what to do if none of the above codes work.
If this helps, please give a rating!
Oct 09, 2009 | Tivo Series2 TCD649080 Video Recorder
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
Jan 27, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Need to program a directv philips series 2 remote
tivo button is the Directv button (tivo home) at the top of the remote. if u have the new directv remote, the tivo home button is the menu button. remote needs to be on satellite. to program codes.
Dec 20, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
My Polaroid TV model not listed, it's TLX-04240B
Can the remote do a code search? I had to do that with my Tivo remote to control my new Polaroid.
Nov 26, 2007 | Polaroid FLM-4201 42 in. LCD Television
TIVO Remote
Your tv doesn't accept the code. The tivo remote uses the code that is programmed in it to control your tv. Go through settings and tell it you want to program your remote for your tv and follow the on screen instructions.
Oct 08, 2007 | Tivo DirectTV Remote Remote Control
Polaroid TLA-01911C TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
