I want to increase my computer's memory capacity, and I have a new memory card for my Compaq Presario SR1110NX, but I don't know where to install it. I don't know where the memory slots are located because I've never installed a memory chip before. Thanks for your help.
SOURCE: iNSTALLING A NEW MEMORY CARD
first check your new memory if its compatible with you computer or motherboard. then just insert it gently and correctly. you will see on your new memory that it has cut that to be inserted on the middle of the slot of the motherboard's memory interface. try to check this one also
http://www.ehow.com/how_2070086_install-new-memory.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
thank you for using fixya
CHARCOIS
SOURCE: Installing a new video card
first your budget
second the interface (PCIe, AGP)
if you are planning to install SLI video cards...make sure you have enough expansion slot for your card..
check your computer Specification in HP website
Since you are Using AMD CPU, its better to get ATI chipset Video Card
SOURCE: INSTALLING GRAPHICS CARD
You have One AGP 8X slot ,so add the same specification card.
For resetting the password of bios
SOURCE: what type of memory is needed for Compaq Presario SR1110NX?
If you ctrl-alt-delete and view processes in task manager you might try to isolate anything that may be running in the background and using up alot of your RAM. It may also be indicative that you have some type of malware; maybe try to run the freeware programs spybot or adaware and remove any virii found.
If you want new RAM it looks like you need to go for PC2700 DDR SDRAM DIMMs; your computer can hold a maximum of 2 GB.
You may find some RAM on eBay for relatively cheap; if you want it new I would goto memorystock http://www.memorystock.com/memory/CompaqPresarioSR1110NX.html
Good Luck!
