SOURCE: NECESITO ME AYUDES CON EL CODIGO DE MI RADIO HONDA CIVIC 2001
Buenas noches desde España. Afortunadamente, solo el concesionario de Honda tienen acceso para estos códigos. El que se tiene que hacer es ir al concesionario con los datos del coche, tal vez te cobren o tal vez no. Buena suerte!
The system can be tested by the dealer with a special scanner. I suggest you have the test run as every part pf the system is very expensive.
SOURCE: Tengo un cb mexon mcb60 pero no tengo el manual , donde lo puedo hallar o conseguir
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to Factory Installed Systems not
add on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
