Question about Apple PowerMac G5 Dual Mac Desktop
PowerMac G5 fan keeps running -- LOUDLY
I have a three-year-old PowerMac G5 desktop, the last of the pre-Intel dual-core models. I'm pretty sure you don't need all the specs to answer my question, because the problem is with the fan. Three days ago, it came on and since then, so long as the machine is awake, it never shuts off. It has GOT to be about 120db, ridiculously loud. It used to only come on when the machine locked up, in conjunction with the red light of death lighting up on the front of the tower. But now it has come on with the machine still running and never shuts off. It is like sitting in the room with a jet engine. I suspect this either means my CPU is running hot, or else my thermostat has gone buggy and just THINKS it's running hot.
Suggestions on how to shut it off without disconnecting it?
    Problem Solver:
  • 6 Answers
I had the same problem... It is the logic board... You need to get it replaced. One way you could try to fix it by resetting the board there should be a little black dot behind the front two fans when you open it up. Press and hold for a few seconds... this resets the board to factory settings. The other way is replace the internal battery. and the third is to replace the logic board. $150-200
Posted on Jun 21, 2009
I was having the same FANS RUN RIOT problem but only when I left the OSx LEOPARD install disk in it...with the install disk in..It would somehow wake FROM SLEEP to a 757 aircraft engine roar
Posted on May 25, 2012
SOURCE:
Nvidia Quadro FX4500 video card in my PowerMac G5 quad. Fan runs, but screens receive no signal. There is 12v at the cord at the rear of the card.
Then process of elimination would tell me the card is defective or you have no firmware loaded for the card.
Oct 26, 2016 | Nvidia Computers & Internet
My G5 freezes constantly. What can I do.
Try running Apple Hardware Test on the machine (it's one of the discs that came with the machine.) Also, if it's freezing by showing the spinning rainbow cursor (beachballing) you may have a failing hard drive. That wouldn't be uncommon for how old the machine is.
Feb 24, 2015 | Apple PowerMac G5 Dual Mac Desktop
Upgrade for a 2005 apple mac desktop tiger 10.4
The highest you can get up to is leopard 10.5. Unfortunately, after 10.5 Apple moved to Intel getting rid of the powermac processors.
Depending on your specs I would recommend sticking with tiger, but leopard should run fin on your powermac. It runs great on mine.
Jul 22, 2013 | Apple Power Mac G5 Desktop
Video jitter on youtube on power pc
Try using the browser Google Chrome, it has flash built in and it is a bit faster.
If this doesn't work, you'll have to kill some programs to get more processing power. Press and hold the command key, and then tap tab while still holding command to cycle through your running programs. Let go to stop on one you kill, and then press Command + q to kill it. Do this with as many programs as you can to get better performance, you can always start them up again later.
If none of this works, you may need to upgrade your graphics card...sorry.
Apr 14, 2012 | Apple PowerMac G5 Dual Mac Desktop
Fans don't run
Thank you for the complete and literate problem statement.
The red light in question will come on and the media bay fan will spin at high speed if the plastic air deflector door is not in place, OR the white sensor label on the lower right tab of the air deflector door is damaged or out of position, OR the air deflector sensor board is faulty.
You can differentiate a bad sensor label from a bad sensor board by doing the following: Remove the air deflector door. Slide a folded piece of paper through the slot in the enclosure where the right tab of the air deflector would normally be inserted. If the red LED goes out (but stays on with the door in place), the sensor label on the door is missing or damaged.
You will also want to check the sensor board cable connection on the logic board (second from right connector located directly below the hard drives).
Subsequent failure for the fans to run does not necessarily indicate a problem, as the fans are temperature-controlled and will not run until heat rises to a certain level. If the fans are not coming on even when the heat is sufficient, you may need to reset the SMU by shutting down the computer, unplugging the AC cord, waiting 15 seconds, and then replugging and restarting the computer.
May 13, 2010 | Apple PowerMac G5 Dual Mac Desktop
Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
Jan 03, 2010 | Apple PowerMac G5 Dual Mac Desktop
PowerMac G5 with dual 2.7 processors powers on but no video
There are seven diagnostic LEDs near the memory banks of this model: six in a tight line between the edge of the logic board and DIMM bank 1, and the seventh just underneath DIMM bank 1 and slightly more inboard. Please tell me which of these LEDs are on and I will tell you what they mean.
Sep 25, 2009 | Apple Power Mac G5 Desktop
Power Supply blew up, need to replace
Hi, Sorry to hear you are having problems,
Here is a very useful website:
http://g5.bhmm.net/
it will show you how to take apart a Powermac G5 step by step.
Mar 16, 2009 | Apple PowerMac G5 Dual Mac Desktop
I have an apple G5 single core
It sounds like you're asking to see if you can add a "core" to your G5. If so, that's not a possibility. Dual core is nice but the G5 is still a powerful machine. If you've maxed out your ram and running a good graphics card and you're still having problems running programs then you should consider an upgrade to a dual core/quad core machine.
Jan 04, 2009 | Apple Power Mac G5 Desktop
Apple PowerMac G5 Dual Mac Desktop Logo
1,454 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
