SOURCE: kyocera fs 1124 printer unknown toner error how to clear
Well u haven't given me much info but is it a colour laser or black and white? Either way -if it's a toner error, this can span from a poor refilled cartridge (most companies are good at this by now) it could be a micro switch. Or it could be the fuser. Concept of a laser printer for you: receives info through either parallel port, USB, wireless, rs232 - whichever. Then projects radiation onto page - passes under toner roller then under fuser from memory which is 300 degrees c or lower this bakes toner onto page and out it comes from output. Check for damage to fuser? - when it's cold, is at a refilled cart? You could blow out printer with an airline but do not discharge to atmosphere and wear a mask. And there will be contacts where cart talks to printer - clean these. The other dafty is to take toner cart(s) out and shake side to side like maraca's to redistribute toner. 13 yrs in the trade tought me most of these little tricks. If no evail- try your old cart and see if it brings up an empty code. Or get a genuine cart(s) or it could be a duff switch or board. But keep it simple for now - it's usually the simple thing. Good luck, Andy.
