I could not find a scanner error 2.
But frequently the scanners in these units require replacement. Unless you have it under maintenance contract the cost of repairs could be prohibitive in a unit this old.
Here is the service manual if it will help you define your problem better.
https://www.printertec.com.br/arquivos_download/3050.pdf
SOURCE: Error 60 02 on a HP LJ 4250DTN
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
SOURCE: HP 2430tn lj printer with 13.20 jam inside top cover error
This question is directed at Steve from the post above. I need to order the sensor you mentioned. Is that sensor located exclusively on the power supply (Part number RM1-1505-000CN)? Will I need to order the whole power supply, or can I order the sensor separately? It does not show it very clearly in the service and maintenance manual. Thanks for the help!
-Shawn
SOURCE: hp lj 2015dn problem for top 2 LED standard ON in my printer
check your printer motherboard it could be the communication cable from the power board is bad or the mother board that is why it can not scan. that is the problem
SOURCE: my odl hp 3052 scanner
Hi
The Hp LJ 3020 is compactable with windows 7, Click hear and install the windows os driver.
SOURCE: hp lj m1005 scanner error 6
Scan head faulty & it need to replace to solve this issue...Scan head located under flat bed glass, to remove this part flat bed unit need to open..see the snap shot.
