Danco Faucet Cartridge  Logo
E
Evodio mejia Posted on Jan 30, 2014
Cartridge problem I put new cartridge and still have like please wath is the solution
Please give us step by step instruction on how to change ink cartridge?
  • Turn on your printer and raise the lid or press the cartridge changing button.
  • Wait for the cartridge carrier to slide out.
  • Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epson printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
  • Carefully remove the tape from the ink opening on the bottom of new cartridge.
  • Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
  • Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
  • If you have an Epson printer, close the cartridge holder lid and press the cleaning button to charge the cartridge.
  • Close printer cover.
  • 0helpful
    My hp officejet 5610xi all in one showing cartridge error-refer to device documentation to troubleshoot.i changed an new cartridge still showing the same message.please help me to solve this problem.
    If you are not using a HP print cartridge, try pulling out the one you put in, clean the contacts in the print carriage, and put in a different print cartridge - even if it is the same brand as the brand new one you just took out. I just solved the same problem with this method. I think the new black cartridge from Office Depot was defective. Once I cleaned the contacts on the machine and put in a new one, it worked!
    2answers
    Print cartridge will not align
    This could be an issue from remanufacturing. Try a new cartridge from HP.
    Many manufacturers have hardware in the cartridge and the printer that tell the printer "new cartridge". When a cartridge is refilled, you can have that giving a "bad" message.
    I wish that I could be of more help.
    IT DOESNT SEND ANY SIGNAL.... NEW NEDDLE BUT STILL NO SOUND WATH'S RONG WITH IT
    HELLO!
    OK! This sounds like a faulty cartridge or wiring. Borrow another cartridge if possible and if the problem still persists it could be the wiring inside the unit which goes from the arm into the deck and connects to the phono cables - a multi meter is a great tool to have around! Check the continuity from the headshell wiring to the phono plugs also check headshell wires for continuity.
    NOTE: Cartridges DO go faulty - strange as it may seem!
    ALL THE BEST!
    My problem is i have a new cartridge then i was put the printer not detect new cartridge the cartridge is not recognized black and colored. what we do my printer please help me my problem because my n
    Take out the catridge and check for the following:
    1. At the base of the cartridge where a chip like item is, take off or strip off a glue like label if its on the chip surface of the cartridge.
    2. Make sure you place the black and colour cartridge at the right positions.
    3. Check the Cartridge bay in the printer (i.e where you place the cartridge in the printer) for the right color description to help you place the cartridge properly.
    4. Lastly check the cartridge pack or printer manual to make sure the cartridges are compactible with the printer, else return them to the shop for replacement
    Problem with replacing color ink cart. #5
    Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
    1helpful
    New Ink Cartridge not working
    first check the new cartridge tmake sure you took off the thin clear tape on the bottom of the cartridge. if you did then the cart. is falty and go back to store and exchange. please rate me. thanks
    2answers
    MFC 660CN
    message says"removescanner cover,then reinstall cartridge," just renewed cartridge.
    Top Danco Home Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a Danco Home Expert? Answer questions, earn points and help others
