Installed a used deck in my vehicle worked fine when tested at pawn 1. deck displayed SP OFF when we first got it hooked up and now it has no sound
If you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
SOURCE: kenwood kdc-x592 No sound on CD and..
your amp turn on is hooked to the power antenna wire. Swap the blue wires and youll be good to go. Since the power antenna is not needed, when the radio goes off tuner, the 12V signal is turned off. and your amplifier will also then lose its remote turn on.
Reverse the 2 blue wires.
SOURCE: kenwood deck reads protect and won't function
you have one of your speaker wires shorted out to the body of the car somewhere, or the speakers that you installed are bad. That is the only two reasons it will go into protect. Correct the problem, then reset the deck - it should work fine.
Kenwood builds this feature in to protect the outputs - so they dont burn up in the case of shorted speakers or wiring.
SOURCE: this deck is in protect mode
A couple things may cause this:
If a speaker wire shorted out (either a voice coil or the wire itself is grounded; touches the vehicles chassis ground)
Solution: disconnect each speaker from the deck and see if it turns back on. 90% of the time thats the problem.
It could be overheating.
This is what the owners manual says about Protect mode......
The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protegtion function is activated. Wire or insulate the speaker cable properly and press the reset button.
SOURCE: i got a kenwood kdc-x491
use source boton to put the radio on standby, press and hold setup boton, and you will see a hide menu. and find demo mode and turn it off.
Starting SP Mode
1. Type the keys as follows:cleare mode button which appers in yellow color and continue the numbers 107
2. Press the cleare button which appers in red color and hold it down until the SP-mode menu is displayed (about 3 seconds) then switch OFF the machine and switch ON this process re-set the code -thanks
1 2 3
4 5 6
7 8 9
0 #
