HP LaserJet 3050 All-In-One Printer Logo
A
Anonymous Posted on Jan 29, 2014
Error Code 0x620060e1
Above Error Code on product screen. What does it mean?
1helpful
LG Ducted AC Wall controller continuous blinking
If the LED light is blinking or error code CH 00 does show up on the display screen on the air conditioner unit then it means that the product does need to be inspected. This error code coming up to show on the product is a temporary error that is caused by electrical issues then such as power fluctuation.
tip
XBox360 error codes (Three Red Lights of Death, Red Ring of Death, X-Clamp)
Hi.
XBox 360 error codes are displayed with flashing lights in the ring of bi-color LEDs located around the start button, like in the picture below:
They are often called lights of death. The technical name from Microsoft is Light codes.
LEDs located around the start button can be green or red. When they get red it means that there is a problem.
When the XBox is operating normally The leds will be green. The number of green segments indicates the number of controllers connected to the Xbox.
Here a working Xbox with one and four controllers connected to the console:
If the lights are red instead of green, then there is a problem. Here the four common error codes:
A: The code in picture A, with only one red segment on and flashing on the fourth quadrant, means that there had been an hardware failure. The internal component failing is often not specified.
The light code is accompained by an error message on display, telling a numeric code that can better address the cause of the fault. The best thing to do is contacting Microsoft to find out the reason for the code. Depending on the code you may also be asked to perform a secondary error code retrieval procedure.
In the Example above E74 means that there is an hardware fault on video connections or GPU.
B: If the first and fourth quadrant LEDs are on, that means that there had been overheating. Internal fans, CPU and board must be tested.
C: General hardware failure. This means that the console detected an internal failure, but no error code is displayed on screen. Call Microsoft to get instructions on detecting secondary code or sending the console for repair.This error code is commonly called Three Lights of Death.
D: The last error means that there is a problem with the AV connection to the monitor or TV. The code is not displayed if you use HDMI connection, in that case you get an on-screen error code. Test using different cables. If that does not fix the problem, this error means that the XBox Gpu is fried. This error code is commonly called Red Ring of Death or RROD.
In the near future I plan to publish a new article explaining how to troubleshoot secondary error codes. In the meanwhile, if you need more support, you can ask a question to our experts or contact Microsoft.
Regards.
1helpful
Entering code sc 542
Fuser error code press clear modes (yellow) 1 0 7 then hold down the stop key for 5 or so seconds screen will change, cycle power
Error code 148.3 photoshop CS5, what does this mean?
What is Adobe error code 148.3?
Fead this thread, HERE.
Fix Error code 148.3
Download the Adobe Licensing Repair Tool using the following link:
http://www.adobe.com/support/contact/licensing.html
Run the tool as instructed in the link mentioned above accordingly, and see if your issue with Adobe Acrobat persists.
Hope it helps & Good luck.
I have an error on my w8200, on the screen
i have an error on my w8200, on the screen written ERROR E20D01,
what is the code mean?
1helpful
2answers
I don't know what the product code for age of mythology the titans is
I'm not sure if you mean the actual product code how the game is bought or the product key where you install the game with.
If you mean the exact product code (that gets read to buy the product, so NOT for installing the game) for AoM: the titans (the expansion only) it is 805529486478
I myself have a package that include both titans and the regular AoM, and for that it is 805529879355.
If you do not mean the product code but the product key code (TO INSTALL THE GAME), then you should look above your CD, usually it shows "product key" and then 25 letters and numbers. Type that code in to install. If it is not above your CD in the CD box, then look on the backside of your manual.
A CD product key is personal and all codes are unique, meaning if you use the code once, you can't use it again, meaning you can only use your own code, and you cannot for example google it.
I hope it helped. Usually these two get confused, but I think you mean the second one to install it, because the product key isn't good for anything really, except finding the game on a database.
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
3helpful
Error OXc18a0201
the exact meaning of this error code is problem in the main board of the printer.but if the main board is just got hanged due to some printer settings then manyatimes this above mentioned reset procedure helps.but if this do not helps then its time to replace the main board Hi there I It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1.Without turning off the product, disconnect the USB cable from the rear of the product.
2.Remove the cartridges from the product.
3.Wait for the 'Insert Cartridges ' message to display on the control panel.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
2helpful
E 000001-0002
The error code mean your fixing heater isnt getting warm in a specific time.But it can be caused by a power dip.
So try this.
Press the star button and then the no 2 and 8 together press star again.Then you are in service mode.
In service mode sellect "copier" and then "Function"and then"clear"ant then"error" and press the ok on the screen.Swiths the machine at the plug off and on.
And Katchiiing!!!
If it doen't help you will have to contact your Canon dealer to replace that Fixing.
k24674
Grand Canyon Tech
Grand Canyon Tech
