Right side rear door won't open & totally locked,cant open from outside door knob and cant open from inside door knob.actuator on central locking not working.
SOURCE: Golf mk 4 GTI Central locking has ceased to
drivers door latch is bad
Testimonial: "seems to be the popular opinion"
SOURCE: Passenger side rear door only opens from inside.
It sounds like the linkage connecting the door handle to the latch has disengaged....you'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. You can then pull off the weather seal in order to see the inside of the door....
SOURCE: volkswagen t5 caravelle central locking not working deadlocks on!
Turns out the problem was a broken wire at a junction below the carpet below the drivers seat. Took my mechanic 4.5 hours to fix it nightmare had to take seat out handbrake lever etc to get to it!!
SOURCE: I have a VW Polo 1999 and it has a central locking problem
i would check the door lock actuators and also make sure you have a good battery. have your battery tested vw have a lot of electrical issues due to battery problems.
http://www.howtorepairguide.com/2013/02/honda-pilot-rear-door-lock-wont-open.html
This will help.
Thanks.
