Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge. You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
You can purchase replacement hinges and hinge covers here:
http://www.mundocorp.com/m275.html
They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
