My printer does not seem to work. It is displaying a message that says call service 7402:0005942. I am not able to print anything from the computer. What can I do to resolve this manner?
1. Turn off the printer.
2. Press and hold and .
3. Turn on the printer.
4. Release the buttons when Performing Self Test displays.
The message CONFIG MENU displays on the top line of the operator panel.
If that does not fix this issue,With Error Code 900 displayed, press and . Post the complete list of Sub Error Codes on the display.
After turning ON the
power or when cover
is closed, the sensor
detects that the unit is
missing.
1) Is an Error message displayed?
2) Is the LED head properly
mounted?
3) Does the Error take place
again?
Confirm that the lever is in
position.
Replace the toner feed unit.
Replace the ID units.
1 Printer POR Turn the printer off and on several times. If Error Code 900 continues to display, go to step 2.
2 System board Make sure the system board is properly seated in connector J7 on the interconnect board. Turn the machine off and on several times, waiting a few minutes between power on and power off. If Error Code 900 continues to display, go to step 3.
3 Factory defaults Restore factory defaults. See “Restore EP Factory Defaults” on page 3-18. This resets the non-critical areas of the user NVRAM. If Error Code 900 continues to display, go to step 4.
4 Sub error codes With Error Code 900 displayed, press Select and Return. Record the complete list of Sub Error Codes on the display. Check the “Base printer sub error codes” on page 2-6. If none of the Sub Error Codes are listed, then call your next level of support.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Dell
5310n: error message is 900.00 service RIP software
A few of my users were having trouble with a Dell 5310n
printer. The error message on the display was error message is 900.00
service RIP software. When printing large data files, such as a PowerPoint
presentation, the printer would error out.
Per Dell's recommendation I configured the virtual printer to not spool the
print jobs and send them directly to the printer. This seems to have corrected
the issue so far.
Normal
0
false
false
false
font-size:10.0pt;
This is what I foudn working on the same problem.... Dell
the issue so far.
Try doing a nvram Try doing a hard or reset or nvram: 1. Turn the printer off 2. Hold down the right arrow and the cancel button 3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
If the light is orange and green flashing alternately, there might be a service error that requires your printer to be repaired. There might be an error message display.
check your ink cartridge if it is properly installed.
or
If it still doesn't work visit your local dealer or a computer repair shop for assistance.
If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
First remove all paper from fax machine and unplug fax machine from the wall socket for 12 seconds then replug fax machine into wall socket replace paper and try printing
