What i would suggest is to take the micro sd card and delete the menu folder and the menutt.dat and anything else associated with the main menu settings. Drag and drop the games folder or games and saves to the desktop and then format the sd card in FAT32.
I appreciate this may seem a little extreme but i have had quite a lot of experience with NDS flash cartridges and the problem you describe usually happens when the menu.tt file becomes corrupt.
Once the sd card is formatted, re install all the nesessary software (you should have these 3 files on the sd card :
TTmenu folder
ttmenu.dat
ttmenu.sys
but, DO NOT put any games onto it until you have placed it into the nds and turned it on allowing the TTcard to build a menu for the games to be loaded from.
Hope this helps
