One For All URC-9910 LCD Remote Control Logo
R
Ronald Ridley Posted on Jan 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED TO ADD CODE TO URC REMOTE
I WANT TO USE THE REMOTE FOR MY DIRECTV GENIE HD DVR MODEL HR44-700. I DO NOT THINK CODES IN THE REMOTE WILL WORK AS I THINK THE REMOTE WAS MADE BEFORE DIRECT TV EXISTED. I DO NOT KNOW WHO THE MANUFACTURED OF THE GENIE IS. I DO NOT KNOW HOW TO PUT IN NEW CODES WITH THE JP1 CONNECTOR. SO FAR I HAVE BEEN UNABLE TO EVEN SET UP THE JP1 CONNECTOR CABLE ON MY COMPUTER. WHEN I TRIED CALLING THE NUMBER IN THE REMOTE MANUAL I NEVER GOT AN ANSWER AND GAVE UP. URC'S WEBSITE IS NO HELP TO ME.
  • 1 more comment
  • Ronald Ridley
    Ronald Ridley Jan 29, 2014
    I hope this accompanies my original post. I meant to say that I wanted to use my URC-9910 remote for my DirecTV Genie... Instead I used the thinking it would refer back to the topic of : Problem with One For All URC-9910 LCD Remote Control NEED TO ADD CODE TO URC REMOTE. Instead I ended up asking how to use the remote for the Genie on the Genie, which I'm sure left everyone wondering just what I wanted to know. And I'm sorry for the caps. I wasn't 'screaming' I normally type in caps because they are easier for me to read and just didn't notice I was doing it on a forum.
  • Ronald Ridley
    I give up. I do not know how to go back and edit and apparently cannot correct via a comment where I can only read part of one long line. How do I delete my question?
  • Ronald Ridley
    Ronald Ridley Jun 20, 2014
    To Mark Stevens. I clicked 'No, answer wasn't helpful' thinking it would open a comment box as their was not one. You instructions were perfect except for refering to the wrong model URC. All I wanted to say was that I had already tried that and it didn't work. No code orogrammed into the URC-991 will work for a DirecTV Genie DVR.
Jim Dowell
Level 3:
Master:
  • Master 345 Answers
  • Posted on Jan 29, 2014
Jim Dowell
Master
Level 3:
Master:
Answers
345
Questions
0
Helped
121347
Points
1057
Try these instructions and see if they work for your genie remote.
First, have your Genie Mini receiver connected and powered on. Next, grab your RC71 remote and simultaneously hold the "MUTE" + "ENTER" buttons until you see a box appear on your TV screen that says "Applying IR/RF Setup. Please Wait" (this appears after about 5 seconds of holding those buttons). Once complete another dialog box will appear and read, "Your remote is now setup for RF." Click "SELECT" to exit that screen. Next, click the "MENU" button, scroll down to "Settings & Help", then click on "Settings", scroll down to and click on "Remote Control", then click "Program Remote". Next you will have two options, either "Program TV" or "Program Audio Device". Click "Program TV", this takes you to a screen where you need to select what BRAND your TV is. After you have selected your TV brand you will have to select the TV Model ( I recommend looking at the sticker on the back of your TV for the accurate Model number or using your current TV remote to find the model number from the menu screen on your TV for fastest and best results). Once the correct model number is selected, AIM your RC71 remote at the TV and it will AUTOMATICALLY program!
Testimonial: "I'm sorry. In my first sentence I used 'THE' referring to the remote in the topic, the URC-9910. So the sentence reads as if I wanted to used the remote for the Genie to operate the Genie. Very Confusing!"
1 Related Answer
Anonymous
  • 129 Answers
  • Posted on Dec 30, 2007
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
2answers
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV Genie® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your Genie® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Does the Sanyo multimedia prod-III connect to direct tv
What are the DIRECTV TV Apps and how do I access them ...
https://support.directv.com/.../what-are-the-directv-tv-apps-and-...
DirecTVDIRECTV's FREE HD TV Apps are interactive features that let you do all of the below without missing ... How do I connect my Genie® or HD DVR to the Internet?Missing: sanyo ‎multimedia
Media Share - DirecTV
www.directv.com/DTVAPP/content/directv/.../mediashare
DirecTVYou can quickly browse thumbnail images or create a slideshow. ... Set up Media Share by connecting your DIRECTV Plus® HD DVR to your computer.Missing: sanyo
[PDF]Programming a DIRECTV Remote to Work With Your TV
manuals.solidsignal.com/directvrc64forweb.pdf
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Need codes for my LG TV
First try all the codes listed under LG TV in the manual. If none of those work ther probably isn't a code that will work in the remote. I have had no luck in calling the number in the manual to get new codes downloaded into the remote via phone. I also sent an email asking for a replacement that would operate my DirecTV Genie DVR. This was their Guaranty when they sold the 9910. They simply told me they would not honor it. And I told them very clearly what I thought of them, not that it helped solve the problem.
But there may be a solution!
Under the battery compartment on the remote is a connector. On this model it is a JP1 (Not a JP1.1, JP1.x). You will have to find a cable with JP1 on one end and something that will connect to a port on your PC. Then you may be able to download a free program and add the LG TV code to your remote. And also do a lot of other amazing things.
Warning, I have not been able to do this. I do not know how to 'configure a port', but if you have these and other computer skills maybe it will work for you. Here is a link to get you started: http://www.hifi-remote.com/jp1/ Good Luck!
DIRECTV HD DVR REMOTE CODES WILL NOT OPERATE DVR
If you turn off power saver on your tv it should correct the problem...
Universal remote control rf20 code for directv hd-dvr
you will have to buy the logtec harmony 520 remote it programs on internet and works great
Bose remote device code for directv satellite box
im living in st maarten nederlands antillies on the dutchside and i boutgh a sitilite box in newyork i ask the people if that can work in ST.Maarten they said yes but ST.MAARTEN is dish network i cant find the code program for the box that box is direct plus hd dvr directv satilite reciever. please can you help me.
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
1helpful
2answers
Remote control code
ferguson fdt-500 code for one for all remote control (urc-7544)
4helpful
2answers
Vizio and the directv dvr
Vizio recommends using code 11758 or 10178 for Cable/Satellite universal remotes that use five digits such as DirecTV. For four digit Cable/Satellite universal remotes , use 1758 or 0178. For three digit Cable/Satellite universal remotes, such as Dish or Echostar, use 627. These codes typically make the Power, Volume and Mute functions work.
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
