SOURCE: i need to replace a fossil watch band
call foleys or dillards and ask for the number to the company
and thy can assist you
SOURCE: stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
SOURCE: rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
SOURCE: replacement acrylic watch band
I posted the other same request...all I've been able to find is ceramic replacement bands, and nothing clear. These run about $200.00 and for that price we should just replace the watch with a "Toy" which it is copy of...
SOURCE: watch band broke on Paolo Gucci Womens watch PG873WS
I have here the official website of Gucci for your ready reference. You can run through below link to find assistance. Kindly change the country from where you are.
Gucci
