An F5 error code indicates that you need to check the oven door or the
latching switch. The switch is used when cleaning the oven, for safe
closure. If you find that the door or the latch switch do not function,
you may need to replace them
F5-E2
means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
- Disconnect power from unit.
- Check wires and connectors from control to door
switch, then from door switch to control. If no damage to wires and all
connectors okay, proceed to step C.
- Replace door switch.
- Re-apply power.
- Press and hold any key down for 1 minute to clear
F5 failure code from memory. F2 will appear. Press CANCEL and observe
for 1 minute to ensure operation is correct.
2. If door not latched:
- Check wires and connectors from control to latch
switch, then from latch switch to control. If no damage to wires and all
- Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5.
If corrections are made in any step, reconnect power to control. Press
and hold any key for 1 minute to clear R failure code from memory. F2
will appear. Press CANCEL and observe for 1 minute to ensure operation
is correct.
6. If failure remains, disconnect power and replace control.Hope helps.
