Vtech DECT 6.0 Digital Cordless Phone Logo
A
Anonymous Posted on Jan 28, 2014
Increase number of rings before voicemail, vtechcs6419
Need to increase number of rings prior to voicemail.
William Oosterman
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 23, 2016
William Oosterman
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
814
Points
That was a useless answer
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Jul 20, 2014
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442935
Points
622693
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
How to increase ringsbefore answer machine comes on
Change number of rings before voicemail answers
Go to Account overview > My digital phone > Check or manage voicemail & features.On the Voicemail Settings tab, scroll to General Preferences and select Set Number Of Rings Before Voicemail.Choose a setting ranging from 1 ring (6 seconds) to 6 rings (36 seconds).Select Save.
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
5helpful
How to increase ring duration
First of all you need to know the number you dial for voicemail. Make a note of this.
Then, go to the dialpad and dial:
*#61#
and press Call.
A box will popup telling you what the redirect to voicemail delay is. On my handset the default was 15 seconds.
Now, dial:
**61******SECS#
and press Call
where *** is your voicemail number and SECS is the number of seconds you want it to ring for before diverting. For example, on Vodafone UK the voicemail number is 121 so to set the ring for 30 seconds before diverting, dial:
**61*121**30#
Once the box has come up saying it was successful you can use *#61# again to check the setting.
3helpful
2answers
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 • Cell Phones
6helpful
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Does not wait for the 4th ring; sends call to verizon voice mail box after the second ring
Sounds like your service provider(Verizon) has your phone line setup to forward to voicemail on no answer after 2 rings. Call your service provider's customer service number and request that the number of rings for forward no answer be increased to at least 5, then your answer machine can receive and answer your calls after 4 rings but if your line is busy callers can leave a message with your Verizon voicemail service. If you don't want Verizon voicemail to answer any of your calls, you could have them disable the voicemail service. When you call the service provider have a recent bill ready because they may request your account number before they will make any changes.
Nokia 1100 increase no. of rings before going into voicemail
you can not do that only your provider can assign the number of rings before going to VM...so contact them and have them do that for you....
Dec 15, 2008 • Nokia 1100
How do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
1helpful
Change the number of rings - Samsung D500
This is a network related setting. Do the following.
from your home screen, type "* 61 * (voice mail access
number) ** (time in multiples of 5 ) #" and then press SEND. For
example, if my voicemail
access number is 404-555-1212 and I want it to ring for 20 seconds
before forwarding to
voicemail, I would type: *61*14045551212**20#
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
