Water not draining from sump
SOURCE: Ariston LS 620 A Dishwasher
Since, the pump doesn't stop working, it sound like a water level switch issue. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
SOURCE: Indesit dishwasher sump keeps filling up with water when turned on
I had a similar problem every time i bailed the sump out by hand and turned the machine back on it would fill the sump or just shut off.
Having spent ages checking various site it boiled down to one of three things there is a thermostat switch underneath they are know to go on the indesits and cost next to nothing to replace
second cause and most probable is to take machine outside before you do this front cover below front door removes to give access to pump you ll know it the pump because it has a pipe rinning into it and one out on my indesit i turned it upside down and got really easy access to it comes of easily take it to pices bit by bit really easy probably need small allun key depends on model check put for foreign objects , spinx blackpool rock etec etc only kidding it might be a bit of plastic or something that stop the spindle turning freely inside the pump if you find anything clean put back and off you go if pump is knackered you can get them off the web for 4.95
last but not least is the problem that mine actually had in the end and the easiest to fix `water pressure` if there is insufficient water pressure the machine regognised this and activate a shut off valve the machine lights flash you can reset the programme but it still does nt work. take the water pipe off the back put it into a bucket and open the valve you ll now what good pressure looks like mine was poor when i took the adjacent kitchen unit out it transpired a shut off vavle had been placed on the pipework the vavle had never been opened fully by the plumber and was restricting the water supply . take your time dont rush and be methodical take advantage of a local parts supplier ash them what most repairers will do first. it can be very rewarding to find that a/ you can do it and b/youve saved 60 or 70 quid in the process.
ps never mess with the machine whilst connected to the mains or spiky hair might come free with the repair and do take the machine outside or you ll have water evrywhere trust me
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
