Question about Onkyo TX-SR605 Receiver
No sound FM or digital out
FM not important to me ..but when everything quit working was after setup..[Speakers hooked } FM was first thing I tried ..worked push a bottom on remote and no sound output .. I hooked my PC via HDMI .... only have sound via hdmi to TV ..it just passes through the unit and plays through tv speakers with no volume control from the unit ....turn hdmi audio off and TV speakers ..no difference and nothing ,, I bought this unit used and worked fine guy had it all setup ..let it sit for 2 day here before setting it up ..been a denon person.for along time ..but after putting my2307ci in protect mode My fault knocked speaker wires off speaker and they connected ..and the dealer wanting 100 bucks to open the unit up 25 or 50 bucks to diagnose the problem ..then parts on top ..not to happy ..thought I would go new ...didn't like any of the new Denons at all ..I decided to leave Denon ..for a little money ..then the dealer wanted to just look at my denon ..I got this unit to get the feel of it and see if I wanted to go new onkyo if at this helps i plug my setup mike in ..which came with my Denon ..it goes into oudyessey mode push enter/next comes up push enter and nothing ...done factory reset ..I'm at a loss at what to do next Thanks Dave
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry about your issue. I suggest that you reset the receiver. With the receiver on press and hold vcr/dvr and then press on/standby. When the display shows clear let go. The receiver will shut down. Unplug for 30 seconds. Plug back in and turn on. Test audio. This procedure will bring the unit back to factory defaults. If this does not resolve your issue I suggest contacting Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Posted on Mar 03, 2017
4 Suggested Answers
SOURCE:
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
Posted on Jan 06, 2009
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
Hi.. I bought a used vehicle(2010 Ford F 150) which has a farenheit dvd-36 system I tried to play the dvd and the monitor, wire, remote....everything is working good. but, the only problem is that the
OK....Pull the dvd player out. Look to see if it has speaker wires coming off the back. If not, does it have rca plugs???? (red and white). if so then you are gonna need an amplifier to get sound. If it DOES hve speaker wires, chec to see if they are hooked up to the speakers in the vehicle.
Mar 13, 2012 | Farenheit DVD-36 Car DVD Player
I have an Onkyo tx ds777 model and I can only get sound to come out of the front speakers on direct mode. Stereo or any type of surround sound produces no sound at all. I have tried with my mp3 player...
You don't say if all speakers work with the setup procedure. THAT is step 1. Then try FM as it doesn't require any cabling. Then move on to more complex sources like external analog, then digital (and make sure to assign the ports).
Aug 22, 2011 | Onkyo TX-DS777
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Hello, i have a pioneer vsx-d508 receiver, and i cant get any sound from it the thing works but no sound i tried everything the manual said to try but still nothing ,,can someone help me or point me in the...
Is this new or was it working for a while and then failed? Does it otherwise look 'normal'?
Use FM as the source to test because it doesn't have any way to miswire it. Turn the volume to something less than midpoint so you don't blow the speakers when the aha moment arrives.
Look for an unwanted Tape Monitor or Mute activated. Speakers enabled. FM selected for t his test.
Jan 17, 2011 | Pioneer VSX-D508
All of a sudden quit working
may i know what os ur using in ur system? try to check the sound card drivers and try to update and check if not reinstall it. before restarting unplung and plug once and check with ur system?
Dec 08, 2008 | Boston Acoustics BA735 Computer Speakers
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
Onkyo TX-SR605 Receiver Logo
71 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
