SOURCE: Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
SOURCE: Change time on kx-t7731
It also says somewhere that you press PROGRAM from the phone connected to jack #01 and you use the system password...or did you miss that part?
Because it's easy, here's a link to someone else's web site. http://telephonesetup.blogspot.com/2009/02/if-you-have-questions-please-call_4039.html
Carl
SOURCE: When I try to make a call with my Panasonic
That depends on what you have the phone connected to. There's a switch on the base that referrs to EMSS. It's a dual Panasonic SYSTEM phone or Single line cordless. The PITS-PGM NO? means you've pressed the PROGRAM button in the EMSS mode.
Carl
SOURCE: Panasonic KX-T7731 headset mode? Could someone
It's automatic. Press the SP Phone button.
My headset is a TCA-60 and it works in all systems on all Panasonic phones.
Carl
Testimonial: "thanks for the help!"
SOURCE: Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
