Ovens Logo
a
adrian popa Posted on Jan 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Please tell me if is possible to convert 1700 Lincoln Conveyor oven LP in Lincoln conveyor on natural gas
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Jan 28, 2014
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2700147
Points
29284
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 16, 2009
SOURCE: lincoln impinger pizzaoven
could be a defective pot or loose opitical encoder
Illassist
  • 12 Answers
  • Posted on May 25, 2009
SOURCE: Lincoln Conveyor Oven - 1132
Switching phase on products are usually up to UL. You need a good tech and it can be done. If it is marked 3 phase and you make a single, the responsibility falls on the person that did the conversion. Components should be similar from 3 phase to single, just use OEM parts!
amendment2
  • 5 Answers
  • Posted on Jun 24, 2009
SOURCE: Conveyor oven motor won't start
does the motor have a start capacitor. It could either be that or it could also be the control board. Good luck :)
Anonymous
  • 410 Answers
  • Posted on Oct 17, 2010
SOURCE: Hi -- I have a double
Usually the first error code will indicate that the temp. sensor in the oven has failed. (the long wire-like device) Since it is one of the cheaper parts and generally easiest to procure and install, try replacing it first. Good luck, Dale
Anonymous
  • 998 Answers
  • Posted on Jul 11, 2011
SOURCE: Hi, my daughter has an impinger lincoln pizza
First you should check the ac source of the unit if their is a power try to use some device to confirm that there is an ac supply like charger or electric fan, if there is power to the source then you should check the fuse if not busted or if it using a breaker try to turn it of then turn it on it may be defective sometimes the contact of the breaker is not properly contacting to each other this hopping that this may help you. thank's
I have a remanufactured lincoln impinger 1000 gas conveyor pizza oven which I believe was converted to a fast bake 1450 model and the main fan motor on the back is screaming.
If the main fan motor is screaming in your lincoln impinger oven, actually that means the motor is faulty. more so the bearing in the motor are worn out and should be replaced, its easier to replace the motor itself but the motor is very expensive. To save money you can actually replace the bearings your self by opening the back cover in which the motor is mounted, then unmount the motor and disassemble it so you can take out the bearings. take the bearings as a sample to a bearing store so that you can get the size correct.
make sure you get bearings that can handle high temperatures and not those with plastic seals ment for wet or water places.
Convert lp natural gas
To convert a lincoln LP gas oven to a natural gas, you actually first of all need to buy from the supplier an orifice ment for natural gas and change. The difference in the orifices could be in the size of orifice aperture.
The orifice i'm talking about is located in the burner assembly. you got to dis assemble the burner so as to get to it.
After that you need to adjust the main gas manifold when the oven is on. The adjustment must be done such that the pilot flame is not yellowish
Hi i 'm looking for lincoln impinger 1456
Google search "Lincoln impinge" and find your local service agent.
Can you converta lincoln impinger from natural gas to propane
Yes you need to go to your gas company and ask them to convert it to LP use they will change burner orfis hrom Natural use to LP use.
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Gas conversion kit
If the manufacturer can't or won't supply one, check with your local LP gas supplier, if they dont do this type of service they can likely refer you to someone who can, This is not a typical "do it yourself" type project, if its to be used in a commercial application, an unapproved conversion may render the oven unsafe to operate causing a structure fire and bringing down the wrath of your local fire martial.
7helpful
4answers
Lincoln impinger 1050 ( gas and electric)
pilot is on auto ignite sequence you have a big problem
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
