I do not get a red & blue light to blink....I have only seen a blue light on this device
Most bluetooth devices I have seen only have a blue light. They may have printed red/blue light so they can copy/paste these instructions for all models. I did find this video plantronics.com/pairing Most cases I have seen you turn on your head set, put phone in pairing mode then push the answer button and hold it til it flashes and the phone should find it as long as it is still searching for it.
SOURCE: My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
SOURCE: Plantronics Explorer 220 bluetooth won't pair with
Well I got it working, of course, try turning the phone off on again instead of just the bluetooth, it worked. I should have done that before posting the question.
SOURCE: headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each other....it will send you a screen to enter a code. This will be 0000.....enter that...and once they pair...you are good to go.
SOURCE: Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
SOURCE: PAIRING PLANTRONICS BLUETOOTH WITH IPHONE 3G
On your phone. goto the Bluetooth menu and select "Add Device or Add Headset"
Refer here to put the headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
