Motorola htn9042a charger,120v,single unit Logo
A
Anonymous Posted on Jan 28, 2014
The HTN9042A and HTN9630C will not charge my P1225 radios.
eradiostore
Level 3:
  • Motorola Master 1,672 Answers
  • Posted on Dec 17, 2015
eradiostore
Motorola Master
Level 3:
Answers
1672
Questions
0
Helped
796332
Points
4248
Check your batteries. Clean your contacts with a pencil eraser to ensure good connection. Try charging the batteries alone in the charger. This will assure you the problem is not within the radio. (Also, if charging on the radio be certain the radio is turned off.) You may have old or bad batteries if they will not charge on either charger.
1helpful
2answers
Error code p1472 p1225 p1227 p1228 p1226 p1425 p1435 p1421 on 2000 volkswagon bug
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1225 Needle Lift Sensor Malfunction
P1227 Waste gate Failed Closed (Over Pressure)
P1226 Control Sleeve Sensor Malfunction
P1228 Waste gate Failed Open (Under Pressure)
P1421 Catalyst Damage
P1425 EGI Glow Plug Secondary Failure
P1435 A/C Refrigerant Temperature Circuit Range/Performance
You need an expert to loo into this, the dealer is the best option out there, more cost but they will fix it faster.
How do I down load users manual
I am surprised by how hard this is to find. My old links are gone, Motorola Solutions did not bother to carry the links over. So, the manual is very similar to the P1225 and the M1225 (mobile), the LS adds the Trunking features. Nothing is user programmable. The buttons on the front must be programmed by the dealer to do anything, but were usually a direct channel and resume (back to trunked operation). To make any changes, you need the Motorola software, cable and RIB (radio interface box). Parts are still available. They were rugged, good radios we sold hundreds of.
Why does my motorola cp200 speaker mic plug have intermittent connection?
The internal jack on the radio has a bad solder connection on it, very common problem in that model. Take it to a Motorola shop for repair.
1helpful
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Usage range of motorola p1225ls
When using on a conventional channel radio-to-radio without the aid of a trunking system, your range should be up to 2 miles line-of-sight. Talking in and out of a building would reduce range to 1/4 to 1/2 mi. (This is with the user holding the radio upright (not tilted))
When or if using the P1225LS in conjunction with a trunking system you would have the range provided by the system, when you are within the footprint of their towers. Speak with your service provider to find out the expected range.
Best regards.
Users manual Radius P1225
all u need 2 do is google free manual motorola ht1000 or i would see if u can go 2 motoroal.com
2answers
9 codes
I have a 2001 VW Cabrio with most of the same codes (P0411, P0103, P1225-1228, P1451, P1425 and P1472) I've read that replacing the fuel pump relay (about $4 online? http://www.jcwhitney.com/replacement-oe-replacement-fuel-pump-relay/p3068141.jcwx?TID=8000000-01VoCaRep1071035&origin=pla&JCW=1&JCW_SRC=PPC&VSID=d50606y2001j1&gclid=CIyYu5TDhrICFcV7Qgodcy8AoA ) should clear at least P1225-1228, P1425 and P1472 (just haven't tried it yet ( http://answers.yahoo.com/question/index?qid=20090114121750AAnyeAj ))
I know this is an old post but hopefully someone reads this and can help, I'll be checking this page evey so often with my fingers crossed, thanks.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
