The reason is due to the notebook being a very basic model and does not have a built in mic, but you should still be able plug one into the mic slot, i have heard that some mics are not compatible (used to work at the service centre UK) but which ones i do not know.
Open the Control Panel, select Speech Recognition to very the Mic is in working order. Set Up Microphone. Open Sounds to select Mic. If you are trying to setup in a software program, say Skype, open Skype Setting and configure/select Internal Mic and webcam.
If the mic is present, you can access speech recognition software to check if the MIC is working, to do so:
Click Start> Control Panel> Ease Of Access> Speech Recognition Options
Dear sheetaldevbr, Try to connect you video set (cam,speaker,Mic set) to another computer, to find out that probably the problem is in your Laptop PC. Or try to reconfigure your microphone by setting them up on Control panel. Follow these steps: Start>ControlPanel>Sound,Speech and Audio Device and rearrange your Mic Device driver. Or If you run the complete Office (at least 2003) try to run the speech recognition on office and run the training and you can also reconfigure your mic in Micrososft Office software. GoodLuck!
There is one more mic control you are forgetting. In the system tray you have a volume control. When you click it open you would come across another Mic control that slides up and down try using this one. I feel that if you use two of these the handling may become a little easier. Let logitech's control be constant and use this one to handle the speech contents.
Start > Control Panel > Classic view > Speech recognition options - run through set up.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;}
a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;}
a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;}
a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;}
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be
visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Set required mic as default - click on mic font to highlight and click
"Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 80% ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph
displays Not working ? Expand 'Imaging' folder in Device Manager and right click on your webcam text - Update driver software from internet
Failing this, uninstall current webcam software and download from here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
WLM (MSN) Open WLM > Show menu > audio and video setup > set mic as default and test > Next - set webcam as default > Finish
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
