Today's mass produced appliances are made so fast and economically that it is usually cheaper to replace the unit than repair them.
My suggestion is buy a new one.
No idea about your oven in particular, but the set button will get you started. From there use the + and - buttons until you have the correct time set. The ok button should finish it for you. If that don't work try the user manual.
F7 Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock.So first try checking the touch pad buttons.If any of the button got internally stuck then its the cause of error.Release the button and see if that helps.But if all button looks ok then its faulty touch pad causing this error.It has to be replaced.-----------------You can get required part from www.repairclinic.com-------------Thanks.Helpmech.
I wired the oven to a different socket temporarily to check it and all the display lights came on immediately so I assume every thing else will work on a permanent supply.It is in fact a supply problem at the oven supply point and the electrician who rewired the house is coming tomorrow to solve the problem hopefully.
