Cars & Trucks Logo
A
Alvaro Torrejos Posted on Jan 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio stopped working
I have a 2009 Highlander LTD and a had to remplace the battery and now the nav screen and the radio does not work.
atholis
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 56 Answers
  • Posted on Jan 29, 2014
atholis
Expert
Level 2:
New Friend:
Greenhorn:
Answers
56
Questions
0
Helped
14267
Points
109
Check fuses first if none are blown then you well need new nav and radio
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Jan 26, 2009
SOURCE: BMW X5 - 2005
Hi kuldipdhanja this sounds like it could be an internal fault with the video module or the sat nav drive, you could try discontecting the battery negative lead for 15 minutes to reset the control units, you will have to remove the spare wheel and unfasten the air compressor bracket to get to the battery, this fix may only be temporary but it is alot cheaper than replacing parts. regards mark.
Gabe Gilsrud
  • 98 Answers
  • Posted on Jul 21, 2009
SOURCE: 2009 Saturn Outlook radio removal
start by carefully prying the woodgrain/brushed aluminum panel around the column shift upwards. Start at the rear, near the cubby. be very careful not to break it where the panel wraps around the drivers side of the shift indicator. when it is removed, you will see screws holding the next panel on (may be 7mm hex or philips - can't remember...) once removed, you can pry that section off as well exposing the radio and climate control screws. both have to come out to get the radio out. the XM portion is not in this radio, but is actually in the rear end of the truck behind the side panel on the driver's side. Be careful if you go poking around in there, because you may have a power inverter back there feeding 115v power to the center console (entertainment package).
david4411
  • 98 Answers
  • Posted on Aug 09, 2009
SOURCE: 2005 chrysler 300 radio/nav system problem.
it is an internal problem in radio
Anonymous
  • Posted on Mar 12, 2010
SOURCE: the radio on my bmw e46 has topped working and the
did u ever find a solution? running into the exact same problem as we speak! grrr
Anonymous
  • 151 Answers
  • Posted on Jul 13, 2010
SOURCE: Radio/nav system dead
maybe a bad fuse
1helpful
The navigation and radio screen on my 2009 escalade is not working and just blinks the home screen. How can I fix?
Chris, they had a few problems with Escalade nav,/radio usually expensive fix and sometimes doesn't last, a lot of people end up going aftermarket.
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Replacement costs for CD mechanism in 2009 Toyota Highlander Ltd. with navigation system
Replacement costs for CD mechanism in 2009 Toyota ...
www.fixya.com/.../t25860356-replacement_costs_cd_mechanism_in_20...
5 mins ago - replacement costs for CD mechanism in 2009 Toyota Highlander Ltd. with ... You should have hit the dealer up for some of the cost as this ...
WHAT IS PROBLEM IF RADIO/CD PLAYS BUT NAV/RADIO SCREEN IS BLACK
its internal circuit problem in radio ,it selector switch is not moving to radio position,
I have a 2009 Toyota Sienna van and had the battery replaced, the radio will not work now.
Does radio show "CODE" in the display?
Call dealer or look in your owners manual.
4 digit code will get it back.
Always save the "memory" in the systems when changing the battery.
Use an external 12 V. source to keep computer,clock and radio
memory.
Losing memory may cause the engine to NOT idle and run poorly as well.
A 9 V. battery in the cigarette lighter is one way.
I have an Highlander Limiter Hybrid with integrated Navi and 6 cd radio player.how can I listen the radio stations that has odd frequency ?
Hi it sounds like your vehicle was destined for the american market and it will only be tunng in 200Khz steps on the odd frquencies. Chances are the radio will either need to be replaced with one suitable for your county ( new replacement ($$) or secondhand equivalent from wrecker) Most toyota radios ran the same plugs on the basic wiring harness so most anything that fits the hole will work - you will most likely lose the nav function however
1helpful
4answers
I have 2010 Porsche Cayenne and Nav screen just goes black and turns back on - sometimes it does it few times a day sometimes its working fine ..any idea?
1helpful
2004 BMW X5 4.4i Left lights on resulting in flat battery. Car was jump started from another vehicle (Ford Transit van). Everything fine for a few days. Now, intermittently the radio/sat nav goes haywire!...
sounds like your car has the multi function steering wheel, i know on the 7 and 5 series they come out of sync, im not sure why.
its about £75 to get plugged in at the dealers and they reprogram it, sometimes i have had the odd car with a damaged slip ring, it does all sorts of things, 1 in particular kept on beeping the horn,
i would say if u got 1 urs got upset when battery flat.
Apr 22, 2009 • 2009 BMW X5
2answers
Cracked screen on 2004 lexus rx330 nav unit
UNKNOWN BUT TOO REPLACE
IF YOU CAN SEE THE RADIO DON'T REPLACE IT
BUT ITS A LEXUS THE CAR IS 1 OF A KIND IT SELF BESIDES THE CRACK IN THE RADIO
GET A NEW 1 WITH BLUETOOTH by ALPINE and get yo stunt on its 2009
THE WORLD IS CRACKED NOT NAVIE GLASS
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
