Cutter Tools Logo
A
Anonymous Posted on Jan 27, 2014
Stanley quick utility knife number stht10828 need help to change blade nothing seems to mowe to allow blade to be removed this is new Iown several utility knives but do not know how to replace blade so I can use stanley hook blades number11-983 Thank you
Rob Brooks
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 12, 2016
Rob Brooks
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2656
Points
Slide the blade holder all the way out, press on the tab as shown in picture. Pull on blade with other hand. Blade slides right out.
stanley quick utility knife number stht10828 need  - 10_12_2016_7_08_24_am.jpg
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Jun 07, 2017
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975865
Points
13030
I find that the Stanley QuickSlide Utility Knife (STHT10828) also accepts Ace Hardware brand Heavy Duty General Purpose Cutting Blades (,024 inch thick).(Ace Hardware Item # 23305.)
2 Related Answers
ADRIAN
  • 313 Answers
  • Posted on Jul 31, 2010
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
mark24354
Mark T
  • 776 Answers
  • Posted on Nov 20, 2009
SOURCE: WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
I have a stanley fatmax knife but it doesn't have the small yellow button to help insert a new blade. what can I do?
HI!Kindly pull the button on the end of the knife and then after you remove that you can now put the blade of your knife.
How to open stanley fatmax knife 10-778 TO CHANGE THE BLADE. thank you
How do I change the blade on the quick change/instant change knife? Warning: Blades are sharp and can cause serious injury. Be extremely careful when handling blades. Wear eye protection and dispose of used blades properly, such as wrapping in duct tape.
FULLY EXTEND THE BLADE.
Press down and forward again on the slide button until the button is in the full front of the top slot (0 through 3 in the below picture).
Note- the blade must be extended beyond the 3rd detent position. This will cause the slide button to remain in a down position, allowing the blade release button to operate.
PRESS AND HOLD THE BLADE RELEASE BUTTON ON THE FRONT SIDE OF THE KNIFE. (Step 4 in the below picture)
Note- if the blade is not fully extended beyond position 3) , the blade release button will not work.
Remove the old blade carefully.
Insert new blade.
NOW, RELEASE THE BLADE RELEASE BUTTON.
ENSURE THE BLADE IS LOCKED IN PLACE. If the blade does not retract, try carefully giving a slight tug on the blade to reseat.
1helpful
2answers
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
5helpful
2answers
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 • Garden
1helpful
2answers
How do i change the blade in a stanley fatmax?
You do not have to remove any screws. Extend the blade outward using the thumb slide on top of the knife. There is a small black pushbutton on the opposite side from the lock button. Depress the button on the side and using the other hand, grab the blade with your thumb and forefinger to pull the blade out. It may require a little wiggling. Now the new blade can be slide in and locked into place. The black pushbutton controls the locking mechanism that keeps the blade from pulling out.
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
Sorry.
Top Stanley Cutter Tools Experts
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
