Konica Minolta magicolor 2400 Laser Printer Logo
A
Anonymous Posted on Jan 27, 2014
Printer not warming up properly
Starts with a green ready light and on the warm up cycle as it starts the machine stops and error light comes on.
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on May 07, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913137
Points
11959
What does op manual say to do.?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3 Related Answers
Anonymous
  • 170 Answers
  • Posted on Mar 25, 2009
SOURCE: Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
chip_reset
Konica Minolta Error Codes and Solutions
  • 210 Answers
  • Posted on Sep 03, 2009
SOURCE: Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Anonymous
  • 394 Answers
  • Posted on Jan 17, 2011
SOURCE: When I turn my printer
Hi, I am Steve, lets help solve your problem.
From your description it sounds like the imaging unit needs replacing. Here is a link to the service manual - I would double check that before buying one as they are very expensive.
You need to look up troubleshooting, indicator messages.
Good Morning i have a xerox 3100mfp its sowing me a printer error FUSER tEMP
Maybe try this, it woks on Sagem that also produces xerox mfp...
Follow the keystrokes set out below, do not worry about what is on the display unless stated to check. All letters referred to are for the keys on the alpha key pad to the right of the control panel, under the plastic flap.
1st option: Press down arrow, *, #, ok, 1, ok, stop (red button),
Press down arrow, #, T.
The machine returns to the error code. Switch the machine off for 10 seconds, switch
back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, 0 (ZERO), ok, stop.
2nd option
Press down arrow, *, #, ok, 1, ok, stop.
Press down arrow, #, look on the display, press up arrow until "T>>PRINTER" is
displayed. Press ok. The machine returns to the error code. Switch the machine off for 10
seconds, switch it back on. If successful the machine will warm up and come ready.
Press down arrow, *, #, ok, 0 (ZERO), ok, stop.
If this is a recurring problem the firmware on the board may need to be upgraded, or there
is a physical fault with the fuser unit. Low voltage / power surges in the supply power to
the machine may also play a part in the occurrence of the error.
The firmware needs to be version 1.10.
To check the firmware version do the following:
Press down arrow, *, W
Firmware version is displayed. Press stop to clear screen.
5401:
Press *
The trace lists will be printed, firmware version is after PRT, as in example below.
In this example, the printer firmware is: PRT V 1.5
It is older than V 1.10 and the printer firmware need to be upgraded.njk
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
My printer HP laserjet P2015, have a problem that no error light blink ready status light on (GREEN) but no test print out and nor other printing by USB cable from computer. Please advice about this i
May be cable loose or heavy dust available in printer that`s why your printer not proper response it. Or may be printer main board damage position so i suggest you contact it printer technician or checking it, which area damage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01764440&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3811075
Thanks,
HP Printer Support
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Green Orange
error cable
After a few seconds
turn on the printer
change to a lower
resolution.
Will not print
It was a warm up problem. When the machine is down for an extended period, it takes about 10 minutes for it to warm up properly and the light will go off.
Will not print
Yeah thats an easy one. Your really out of toner, the density sensor is seeing a light development patch, and the firmware ( machine operating software) does not have a clue what to do.
I suspect, ohhhh about 99.99999999999999999999999999999999999 percent sure if you replace the toner cartridge your machine will warm up, set up in a minute or 2 and run like normal.
I have seen that time and again on that machine, The software sometimes simply doesnt know what to do with a light copy indication.
The out of toner sensor is a window type sensor, so if there is a little remaining toner on the sensor, yet the density sensor looking at the patch on the drum is light, the software has no clue what to do, so the machine runs, and runs, and runs, and runs...... A new toner cartridge is a almost 1000000000000000000000000000000000 percent fix.
Machine stops and F6 appears
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
elem_1_spacer.gifGive this a try, the code is a fuser not warming code. This could resolve it.
Canon CLC 2400
go into service mode and clear ram remember to copy the values before clearing or your dc controll is damage
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
