SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
SOURCE: where is the filter located on a frigidaire
You have to take to back off the washer --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
http://www.frigidaire.com/manuals
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
