Occasionally this will happen. Here are a few tricks to hush the noisy belt. Try using another belt from another manufacturer. Its true you do get what you pay for. A better belt may be the ticket. Another trick is to lightly score the idler pulley with a file all the way around in a cross pattern then lightly sand the pulley to rough up the surface. There is also a spray you can buy called belt dressing that will work. Hope this gives you a reprieve from your earplugs. Good luck Dena.
