Televison & Video Logo
Posted on Jun 03, 2009
Hi Bought this TV combi last week...nightmare!!! L22DP03U First of all...tv doesnt connect to sky remote as the code is not listed on sky...telephoned sky they said contact hitachi...rang them said not their problem contracted out to third party may never be on sky code. Now connected to the remote but no sound from sky remote so have ti use hitachi remote for sound! Second ...put a DVD in to watch last night said wron region...checked on DVD case (bought from HMV) no problem says region 2... tried again no joy! Tonight tried another DVD same problem TV combi says wrong region. Read the manual til fed up with it. Internet for 2hours searching! www.hitachidigitalmedia.com website hopeless... no sign of this model...searched and searched... tried customer services..closed! Basically fed up with what I thought was a reputable make and so a good investment! Can you help to sort out my 2 problems please...aprt from return it to the store! Thankyou
  • elliekeates Jun 06, 2009
    Hi
    No....
    I ended up returning it to the store and getting a refund.
    Went to another store and was told Hitachi were doing a recall on all TVs (not too sure how reliable his information was though!)
    So now back to the drawing board I guess to find an alternative at a good price!
    Hitachi website not at all useful...the model I returned wasnt even listed! So I will be giving them a wide berth
    Hope you find a solution....
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
410
Points
Hey did you get anywhere with this?
I've got exactly the same problem with a TV at my work and can't find anything to resolve it.
2helpful
2answers
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sky+HD remote code for logik L40LCD11
Logik
LK74
726
Logix
LTV3601, RC223
696
1helpful
2answers
Can't find a code for sky remote for my powerpoint combi tv
used the code for phillips and that worked fine
10helpful
2answers
Cannot tune in sky remote no code for neon tv combi
just spoke to neon/cello and there is no remote code as of yet,they reckon sky are making a new remote with the codes listed in the memory so there is nothing we can do ......for now
hope this helped
2helpful
2answers
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Sky remote code
hi need code for sky+ remote to use on hitachi L42VPO1U
1helpful
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
1helpful
1helpful
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
6answers
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
