An authentication error is an incorrect password being entered. Make sure you are typing it in correctly. Remember, passwords are case sensitive. Please check with your internet provider if you are unsure of your Wi-Fi password.
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - 9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
First check if your internet connection works ok by using a lap top or desk top. then make sure you have selected the your internet provider , on i pad. choose the one you use. log in add your pass word user name (the same for your other pcs.) if at a friends place ask them for the account details and their pass word if they will share it. and they should
Hoppy
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
It appears that the wi-fi you are attempting top connect with requires an authentication code. If you are connecting at home, it is the passcode for your router. if a business or pay for service system, you will need an account to connect.
