SOURCE: CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
SOURCE: The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject button......tr it! and let me know!
SOURCE: Help - CD won't eject! I press 'Open' on my sony
I have the same problem and it's due to dirt!
I'm going to try using compressed air, but -
this definitely works:
:) Seriously:
tilt the cd player to a 45 degree angle (flat, basically - as if they tray were horizontal.)
I had my player for 10 or 12 years, and this problem is only coming up now. My house gets very dusty.
Also - vertical load disc players are hard to clean. X_X (inside the disc tray)
I love this stereo too!
I don't want to have to go out and buy another stereo!
SOURCE: Sony CMT-EP515 CD Shelf System. CDs wont play.
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
SOURCE: the CD tray on my Sony MHC-RX100AV system won't
hey dude, i have the exact problem. I took the black wraparound cover off and looked inside and turns out the problem is the belt used to open and close the door. if it is old and worn, chances are it doesn't have enough elasticity to help the rotating parts rotate to open and close the door the whole way.
If your door is open when you remove the cover, you'll see the belt and door-opening mechanism right in the middle of the unit when you look down into it.
the belt looks to be about 8" in circumference, and i have a rubber band holding things in place until i can get to the store and get a new one.
hopefully you figured this out without buying a new stereo
