Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
Dont know model but about 4 years old seat ont close slowly
Seat lowers slowly. Why isn't lid doing the same anymore?
Bonnie, tensioner spot worn on seat, allowing seat to close faster now. Replace seat or if not to old ask for a replacement under warranty.
Mar 31, 2016 | Home
B&S Engine Model204412 code 060613YD runs well even under load with choke full will stop if youput choke back to normal
Hi check float level if it's to high ::::::: it's possible the seal inside the needle & seat is faulty u will have to buy a needle & seat package. . cheers
Feb 12, 2018 | Briggs Stratton IC Horizontal OHV Engine ...
Toliet seat lid doesnt drop slowly anymore ( 4 yrs. old )
Either live with it or replace it. The hinge is not serviceable and the soft close action does not last forever. They rarely last more than five years, maximum.
Jun 19, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
Rough idle, condensation comes from tailpipe when cranked. black smoke, and carb.floods with gas . seems to quit when its gets warmed up and then sometimes it dont.
I don't know the year model, if older carb, sounds like stuck choke, bad choke pull off or bad needle and seat in carb. If newer model, computer staying in closed loop, bad temperature sensor.
Feb 12, 2010 | Toyota Pickup Cars & Trucks
Slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Feb 11, 2009 | Kohler Toilet Seat - Elongated Front Quiet...
Akai tv picture problems
i want the cercit digram for akai tv ct-t29sa3a
Nov 16, 2007 | Televison & Video
Leaking icemaker
It sounds like your water valve is occasionally get stuck open and over filling the icemaker.
Oct 29, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Is this seat FAA Approved!?! Help!
As far as I know this seat is approved by the FAA so you can go on your trip with this car seat and feel safe. If you want to be sure I suggest you drop a visit to the manufacturer site.
Oct 09, 2006 | Cosco Alpha Omega 22-180 - with Shield
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
29 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
