The boiler has worked perfectly for 5 years and annually serviced.There is no certainty that the boiler switches off when the programmer requests such - I changed the programmer to a new one and the intermittent problem continues. If I overide the programmer switch to 'on' then 'off' the boiler switches off ! What is likely to be the problem? Where do I look next ?
SOURCE: changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
SOURCE: The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
SOURCE: Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
SOURCE: Free copy of an Ideal Classic LXFF Boiler Manual
no but Ideal will post one out to you on request
SOURCE: on the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
