Drive belt loose on my N 1485 ride on
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
SOURCE: Hi, Just replaced the drive belt on a Husqvarna
My name is Dane and I am going to help you solve your problem.
I looked up your mower and I believe you should be using drive belt# 5321701-40. That is a 112" belt. Here is a link to the parts manual and a drawing of the belt routing. As long as that is the belt you have, and replaced it correctly it should be fine. You are correct, when you put the mower in gear, the pulley system will put more tension on it.
http://weborder.husqvarna.com/order_static/doc/HIPL/HIPL2003/HIPL2003_1063048-61.pdf
Well, I hope I've helped. If you found this information useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Testimonial: "Thankyou Dane, You are a true proffessional!"
