Casio FX9750GII Graphic Calculator Logo
A
Anonymous Posted on Jan 27, 2014
EXE button does not work - Casio FX9750GII Graphic Calculator
Orange sound button will not go off
Audio is working or not...
if not install this " http://ftp.hp.com/pub/softpaq/sp64001-64500/sp64107.exe "
if audio is working but issue with the button the install this
http://ftp.hp.com/pub/softpaq/sp46001-46500/sp46167.exe
Camera launcher.exe does not work anymore
you probably need to uninstall
and re-install the canon program
and ,if you want to fix launcher.exe,There are 3 step to repair launcher.exe stopped working error
If you got launcher.exe stopped working error then there is a 94% chance that your computer has registry problems. To repair launcher.exe stopped working error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair launcher.exe stopped working error.
2answers
Hey ,my name is marcus,i got this little problem in my pc ..vaio sat survey.exe has stopped working..what can i do
I would try to download a patch for that at the sony support website http://esupport.sony.com/ or click on the sony update button at the right bottem of your screen. Good luck
3helpful
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
I want to change start button name
Renaming the Start button needs a few steps (Source: http://www.onecomputerguy.com/windowsxp_tips.htm)
Renaming the Start Button
To rename the start button, you will need a hex editor.
My preference is UltraEdit
  1. Copy the \windows\explore.exe file to a new name (e.g. explorer_1.exe)
  2. With the hex editor, open that file and go to offset 412b6
  3. You will see the word start with blanks between each letter
  4. Edit it be any 5 characters or less
  5. Save the file
  6. Boot to DOS
  7. Copy the existing c:\windows\explorer.exe to explorer.org
  8. Copy explorer_1.exe to explorer.exe
  9. You will also need to replace the explorer.exe in the c:\windows\system32\dllcache file as well with the new one.
Note: If the partition is NTFS and you can't access the files from DOS:
  1. Start Regedit
  2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon.
  3. Change the value of Shell from Explorer.exe to explorer_1.exe
Hope this helps. Please rate your feedback!
Thanks,
VJ
Internet Explorer problem
Step 1: Use Windows File Search Tool to Find msas2009.exe Path Go to Start > Search > All Files or Folders.
  1. In the "All or part of the the file name" section, type in "msas2009.exe" file name(s).
  2. To get better results, select "Look in: Local Hard Drives" or "Look in: My Computer" and then click "Search" button.
  3. When Windows finishes your search, hover over the "In Folder" of "msas2009.exe", highlight the file and copy/paste the path into the address bar. Save the file's path on your clipboard because you'll need the file path to delete msas2009.exe in the following manual removal steps.
Step 2: Use Windows Task Manager to Remove msas2009.exe Processes
  1. To open the Windows Task Manager, use the combination of CTRL+ALT+DEL or CTRL+SHIFT+ESC.
  2. Click on the "Image Name" button to search for "msas2009.exe" process by name.
  3. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
Step 3: Detect and Delete Other msas2009.exe Files
  1. To open the Windows Command Prompt, go to Start > Run > cmd and then press the "OK" button.
  2. Type in "dir /A name_of_the_folder" (for example, C:\Spyware-folder), which will display the folder's content even the hidden files.
  3. To change directory, type in "cd name_of_the_folder".
  4. Once you have the file you're looking for type in del "name_of_the_file".
  5. To delete a file in folder, type in "del name_of_the_file".
  6. To delete the entire folder, type in "rmdir /S name_of_the_folder".
  7. Select the "msas2009.exe" process and click on the "End Process" button to kill it.
MSAS2009 IS SPYWARE!
good luck!
Volume buttons
Hello Gavrilov,
As I understand that you are facing issue with the Qucik Touch buttons of the volume on the notebook.
If this is correct, install the Quick Touch buttons drivers on the notebook.
Here are the drivers for Quick touch buttons:
Windows XP:
ftp://ftp.hp.com/pub/softpaq/sp29501-30000/sp29528.exe
or
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39425.exe
Windows Vista:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
No icons
wow so much information to work with :) If you have not restarted your computer then try ctrl alt delete key and make sure your explorer.exe is running.. if not click new task and type in explorer.exe.. If this happens on boot something is crashing explorer.exe.. probably a virus..
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
