Polar F6 Wrist Watch Logo
A
Anonymous Posted on Jan 27, 2014
Polar rcx5 beeping - Polar F6 Wrist Watch
tip
Polar Heart Rate Monitor User Manuals
Having Trouble with your Polar Heart Rate Monitor but can't find your manual? Follow this link to download a new copy.
Don't see your Polar on the list, then your Polar is most likely over 12 years old and you will have to contact Polar directly.
USA/ Canada = www.polarusa.com
Rest of the world = www.polar.fi
on Nov 24, 2010 • Watches
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 • Watches
5helpful
2answers
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
1helpful
I have turned my sound off on my watch and the alarm sound but when I am working out my watch beeps at every heart rate, its annoying I know there is a way to have no sound, I had it that way before but...
Assuming that your limits are set correctly, this is a job for a Polar Authorized service center.
There is most likely a problem with the computer, depending on the age of the watch this will be taken care of under warranty. The link above explains the process.
If you replaced the battery yourself (never recommended) some contaminant could have gotten into the electronics, or the seal is no longer working allowing moisture into the unit. These are highly sensitive electronics and should only be handled through the service centers. The work they do is covered with a warranty and they replace seals and vaccuum pressure the watch to make water tight again, as well as run a diagnostic on the computer.
In the mean time if you don't want to send in you can set the Heart Rate limits - both low and high well above your actual limits and that will stop the beeping, as the beeping while you are working out is an out of limit/ zone alarm.
4helpful
How do i get it to stop beeping while i am exercising
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please
3helpful
Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
7helpful
Problem to Sync with my Polar F6
The only solution here can be: You have to completely reset your watch and then try to synchronize it again. In case if you've lost instructions, download them here:
www.polardiscount.com/scripts/prodView.asp?idProduct=76 - 87k - Cached - Similar pages
On the right side of the screen you will see:
Polar F6- Black Coal manual.
Click on it and get full instructions.
If all this do not work, you'll need to find your nearest watch repair shop and ask for help.
Do not forget to rate please.
4helpful
3answers
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Timex Expedition watch
I bought this for my son and he has been living with it for 4 months, and hour and ten min. off !  I just want to set the time, and I'm at the top of the world, no radio shack down the road.  Turn right at the polar bear.
Top Polar Watches Experts
NOEL
NOEL
vince
Alex Kimuyu
Are you a Polar Watch Expert? Answer questions, earn points and help others
